andymat
- Nov 4, 2009
- 2
I am trying to define a geometrical tolerance scheme to control two separate faces to be in the same plane.
I can define one face as a datum and control the other parallel to within a tolerance band. And if the faces were offset from one another, I could place a basic dimension which would control the distance. But since I want them coincident, I cannot put a basic dimension of '0'.
Do I need to add an additional position tolerance? Or can anyone suggest a better way to achieve a tolerance between 2 parallel and coincident faces?
Many thanks.
Many thanks.
