saiedmehdipour
Chemical
- Dec 7, 2008
- 5
Dear All,
would you please do me a favor and tell me the scientific reason of merked item on attached file:
1-why usually used 2 ESD on/off valve in parallel mode and furnished them by PDT (also the reason of PDT and typical allowable DP in both side of ESD valves, according which standard.)in inlet of seperator suction drum.
2-beside why usually used temporary strainer at the nearest place inlet of compressor and furnished it with PDT and ESD signal(what is the typical allowable range of PDT for shutdown,according which standard).
Notes on attached file refer to:
Note2 : "not fully open" status of XV-019 to trip compressor.
Note4 : temporary strainer at minimum distance from compressor inlet.
Note27: open of the main shutdown valve (XV-019) is not allwed when there is a large differantial pressure.
By Best Wishes,
By Best Wishes,
