veryuniqueid
Computer
- May 8, 2008
- 10
- 0
- 0
I am using an NTD70N03R mosfet from On Semiconductor in a half bridge configuration and would like to put several of them in parallel to handle more current (i.e. instead of 2 mosfets, I will have 6) Assuming I can generate the drive current to do this (I'm using a FAN7382 to drive it) my concern is dissipating the heat.
The circuit could draw about 100A which should divide about evenly between the three parallel mosfets and be within their ratings. Running 100A through a PC board trace seems excessive, so I'm looking at using 1/8inch by 1/2inch by about 2inches copper busbar. I am planning to solder the mosfets to the busbar so in addition to being a conductor it will also act as a heat sink. The gate pins will be soldered to a trace on the board, and the source pins will be soldered to another copper busbar.
My questions are one: is this a reasonable way to parallel mosfets and two: will the busbar provide enough of a heat sink?
Thanks for your help.
Ed
Ed
