SAK9
- Apr 12, 2002
- 603
Guys,
In a biosafety lab exhaust system,we have 2 fans each sized for 100% air flow capacity and pressure connected in parallel.Is it possible to run both the fans together at reduced speed so that in the event of one of them failing the other can quickly run up to full speed and takeover?How will we determine the speed and power consumption for the fan?What is the best way to control the speed? Duct static pressure control?
My concern are:
1) At reduced speeds the fan may develop less static pressure and may not be sufficient to overcome the system resistance
2)Running both fans together will not be energy efficient.
I would like to hear from those have tried this.
