I have two VFD pumps emptying wet well. It is defined Duty 1 and Duty 2 Start and Stop setpoint and pumps minimum and maximum speed.
If we have just one (Duty 1) pump running speed is easily defined by the slope (MaxSpeed-MinSpeed)/(Duty1StartLevel-Duty1StopLevel).
In case when the level is above Duty2StartLevel we will have two pumps running in parallel (Duty2StopLevel is above Duty1StopLevel as it is Duty2StartLevel above Duty1StartLevel.
What would be the speed of the pumps running in parallel? Thank you for any help and ideas.
