GUchida
- Feb 9, 2021
- 3
I'm currently designing some parts where the datum reference frame is formed by the following datum features: Bottom surface called A, Dowel Hole perperdincular to A at MMC, called B, and Dowel Slot referenced to A and B, called C. (See IMG1.png and IMG2.png attached)
I need to ensure a surface that is paralell to the plane generated by the axis of B and C that are perpendicular to A. And I'm in doubt of which of the options are the correct one. (See IMG2.png attached)
Thank you in advance.
