parameter + Formula + relations
DomKum
Automotive
Nov 27, 2005
23
Hi Experts
May I request for help to correct this issue.
Trying to create a sphere with exiting points. Requirement is to create a sphere with parameter. I followed your youtube video but not able to fix the problem.
Not able to create formula to connect to radius of sphere.
Language=”VBSCRIPT”
‘This MACRO is to create a parametric sphere with diameter as input
‘points in GS
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set parameters1 = part1.Parameters
Set hybridBodies1 = part1.HybridBodies
‘Set hybridShapes1 = hybridBody1.HybridShapes
Set axisSystems1 = part1.AxisSystems
msgbox (“Select the geometrical set with I/P points for creating Sphere”)
Dim oSelection ‘as Selection
Dim InputObjectType(0)
Set oSelection = CATIA.ActiveDocument.Selection
oSelection.Clear
InputObjectType(0) = “HybridBody”
Status = oSelection.SelectElement2(InputObjectType, “Select Geometrical set.”, True)
Set hybridBody1 = hybridBodies1.Add()
Set hybridBody1 = CATIA.ActiveDocument.Part.InWorkObject
Dim length1 ‘As Dimension
Set length1 = parameters1.CreateDimension(“”, “LENGTH”, 0.000000)
length1.Rename “SPDia”
length1.Value = 25.000000
‘Spheredia=Inputbox(“Enter Diameter of sphere to be created”)
Dim iCount
Dim i ‘As Integer
oSelection.Search “CATGmoSearch.Point,sel”
iCount = oSelection.Count
For i = 1 to iCount
Set hybridShapePointOnSurface1 = oSelection.Item(i).Value
Dim reference1 ‘As reference
Set reference1 = part1.CreateReferenceFromObject(hybridShapePointOnSurface1)
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim relations1 ‘As Relations
Set relations1 = part1.Relations
Dim formula1 ‘As Formula
Set formula1 = relations1.CreateFormula(“Formula.2”, “”, length1, SPDia)
formula1.Rename “Formula.2”
Set hybridShapeSphere1 = hybridShapeFactory1.AddNewSphere(reference1, Nothing, SPDia, -45.000000, 45.000000, 0.000000, 180.000000)
hybridShapeSphere1.Limitation = 1
hybridBody1.AppendHybridShape hybridShapeSphere1
part1.InWorkObject = hybridShapeSphere1
hybridShapeSphere1.name = “Shpere for-” & oSelection.Item(i).Value.name
‘part1.Update
NEXT
part1.Update
msgbox (“Total number of sphere created -” & iCount)
End Sub
Sub CATMain()
MsgBox ("Select the geometrical set with I/P points for creating Sphere")
Dim oSelection 'as Selection
oSelection.Clear
InputObjectType(0) = "HybridBody"
Status = oSelection.SelectElement2(InputObjectType, "Select Geometrical set.", True)
Dim length1 'As Dimension
Set length1 = parameters1.CreateDimension("", "LENGTH", 0)
length1.Rename "SPDia"
length1.Value = 25
'Spheredia=Inputbox("Enter Diameter of sphere to be created")
Dim iCount
Dim i 'As Integer
oSelection.Search "CATGmoSearch.Point, sel"
For i = 1 To iCount
Set hybridShapePointOnSurface1 = oSelection.item(i).Value
Dim reference1 'As reference
Dim relations1 'As Relations
Set hybridShapeSphere1 = hybridShapeFactory1.AddNewSphere(reference1, Nothing, length1.Value, -45#, 45#, 0#, 180#)
Dim myradius
Set myradius = hybridShapeSphere1.Radius
Dim formula1 'As Formula
Set formula1 = relations1.CreateFormula("Formula.2", "", myradius, SPDia)
formula1.Rename "Formula.2"
hybridShapeSphere1.name = "Shpere for-" & oSelection.item(i).Value.name
Next
part1.Update
MsgBox ("Total number of sphere created -" & iCount)
End Sub
regards,
LWolf
two changes: in Set HybridShapeSphere1 you need a value of the radius...
and then I added myradius, which takes the sphereradius as its reference...
regards,
LWolf
disregard my inputs... just realised you want to have the parameter controlling your sphere...
regards,
LWolf
ok, sorry for all the spam, delete doesn't work for me today...
here is my last input, (i promise)
here is the working code... I changed the formula to go for the parameter.name ( Set formula1 = relations1.CreateFormula("Formula.2", "", myradius, parameters1.item("SPDia").name))
Sub CATMain()
oSelection.Clear
Set length1 = parameters1.CreateDimension("MM", "LENGTH", 25)
Dim iCount
Dim i 'As Integer
For i = 1 To iCount
Dim myradius
'formula1.Rename "Formula.2"
Next
part1.Update
End Sub
regards,
LWolf
Thank you LWolf for your suggestion & guidance.
Its working now.
Hi LWolf,
I just forgot to mention that with the code as below - I mean # included in the script, Macro is showing an error while I try to exeucte.
However replacing # with -45.000/etc its working fine.
