jdgengineer
- Dec 1, 2011
- 748
I am designing a concrete spandrel beam with a parapet above. The beam is 18" x 28" and has an 8" thick concrete parapet wall above. From the bottom of the concrete beam to top of the parapet is 54".
Would you design this beam as a rectangular 18" x 28" concrete beam or would you design as an L-shaped beam including the parapet? We can handle the torsion design of the beam in either consideration. My preference would be to design as 18" x 28" but I'm afraid if I design it that way that the beam would be overly reinforced as the "top" steel would actually be "bottom" steel when including the parapet height.
Thoughts?
Thoughts?
