Parasolid export version
MCADTrans
Is it possible in NX9 to set a default parasolid export version?
I see customer defaults for everything except parasolid.
I am exporting parasolids quite often using an earlier version due to the capabilities of the software I am importing it in to.
Bart
Thank You.
I try this to be sure, if something is selected but I get an error:
Code:
	lw.open
	For each tempBody as Body in workpart.Bodies
 	   if tempBody.Layer = 1 then
 	       theBodies.Add(tempBody)
 	   end if
	Next
        For Each temp As Body In theBodies
            lw.WriteLine(temp.Tag.ToString)
        Next
37441
*** ERROR ***
650004 : Incorrect object for this operation.
With best regards
Michael
The .net exception mechanism always reports the line(s) of code in which an unhandled error occurs. It would be helpful if you could clearly indicate which line of code was reported. Perhaps highlight the posted line of code in which the error occurred.
Also, it would be helpful to know how "theBodies" and "workPart" are defined in your code.
www.nxjournaling.com
This is error from listing window, so there wasn't any line no. It appears when I uncomment lw.writeline(temp.Tag.ToString).
Below is actual code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports Microsoft.VisualBasic
Imports System.Collections.Generic
Module NXJournal
    Sub Main()
       Dim theSession As Session = Session.GetSession()
       Dim ufs As UFSession = UFSession.GetUFSession()
       Dim workPart As Part = theSession.Parts.Work
       Dim displayPart As Part = theSession.Parts.Display
       Dim lw As ListingWindow = theSession.ListingWindow
'       Dim tagList() As NXOpen.Tag
       Dim exportFileName As String = Nothing
       Dim exportFileName1 As String = Nothing
       Dim nazwa as string
       Dim path As String
       Dim PSversion as integer = 240
       Dim layerNumber as Integer = 1
       Dim i As Integer = 0
       Dim theBodies As New List(Of Body)
       Dim inx As Integer = 0
	lw.open
 	   end if
	Next
'        For Each temp As Body In theBodies
'            lw.WriteLine(temp.Tag.ToString)
'        Next
    Dim bodyCount As Integer = thebodies.ToArray.Length
    Dim tagList(bodyCount - 1) As NXOpen.Tag
    Do
        tagList(inx) = workPart.Bodies.ToArray(inx).Tag
        inx = inx + 1
    Loop Until inx = bodyCount
'       ReDim tagList(thebodies.GetUpperBound(0))
'       For i = 0 To thebodies.GetUpperBound(0)
'           tagList(i) = thebodies(i).Tag
'       next
       exportFileName = workPart.FullPath
       nazwa = workPart.Leaf
       path = IO.Path.Combine(IO.Path.GetDirectoryName(workPart.FullPath), "step")
	If(Not System.IO.Directory.Exists(Path)) Then
    		System.IO.Directory.CreateDirectory(Path)
	End If
	exportFileName = IO.Path.Combine(path, nazwa & ".x_t")
       'if this file already exists, delete it
       If My.Computer.FileSystem.FileExists(exportFileName) Then
           My.Computer.FileSystem.DeleteFile(exportFileName)
       End If
        Dim numUnexported As Integer
       Try
       ufs.Ps.ExportLinkedData(Taglist, Taglist.Length, exportFileName, PSversion, Nothing, numUnexported, Nothing)
       Catch ex As NXException
           lw.WriteLine("*** ERROR ***")
           lw.WriteLine(ex.ErrorCode.ToString & " : " & ex.Message)
       End Try
        lw.Close()
     End Sub
 End Module
It's working but not I desired. It's generating parasolid, but when I open It in NX I only see body from layer 99 (reference set "FALSE").
When I add another body on layer 1, then in imported parasolid I have assembly with 2 parts, one with false, and second with true (first body). I think the code which respond for taglist is broken.
I commented "Redim (..)" from the first code, because I received an error:
"Element '.GetUpperBound' is not the member of element 'system.collections.generic.list(of NXOpen.Body)' "
With best regards
Michael
If the error message shows up in the listing window (and not in a .net error message box) then it must be coming from this portion of your code:
Code:
Try
    ufs.Ps.ExportLinkedData(tagList, tagList.Length, exportFileName, PSversion, Nothing, numUnexported, Nothing)
End Try
The error is caught and handled in your code. The error occurs in the .ExportLinkedData function and your code responds by writing the error message to the listing window. The fact that the error occurred after you uncommented the "lw.writeline" code is most likely just coincidental.
Ultimately, the .ExportLinkedData function needs an array of body tags. Your code to retrieve the body tags is problematic. It ignores the bodies that you have found on layer 1 (if any) and indiscriminately uses the first n bodies that it finds in the body collection. Since we only need the body tags and not the bodies themselves, we can dispense with the list of Bodies and use a list of Tags instead.
Code:
Dim theBodyTags as New List(Of Tag)
For Each tempBody As Body In workPart.Bodies
    If tempBody.Layer = 1 Then
        theBodyTags.Add(tempBody.Tag)
    End If
Next
lw.WriteLine("number of bodies found: " & theBodyTags.Count.ToString)
if theBodyTags.Count = 0 then
    'no bodies to export
    return
end if
Then in the .ExportLinkedData function, we can use:
Code:
ufs.Ps.ExportLinkedData(theBodyTags.ToArray, theBodyTags.Count, exportFileName, PSversion, Nothing, numUnexported, Nothing)
p.s. Don't run this code in an assembly file; it won't run as you expect. First get it working in a part file.
Thanks Cowski, You are Great, now it's wok perfect. Now I start with whole assembly journal.
I wish I could know VB like You know. I bought book "Beginning Visual Basic 2005" Thearon Wills, but I haven't much time to study it.
With best regards
Michael
Ok, here is my code, maybe it will be useful to someone else in the future:
Code:
'Journal to recursively walk through the assembly structure
' will run on assemblies or piece parts
' will step through all components of the displayed part
'NX 7.5, native
'NXJournaling.com February 24, 2012
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Public lw As ListingWindow = theSession.ListingWindow
    Sub Main()
    Dim dispPart As Part = theSession.Parts.Display
    lw.Open
    Try
        Dim c As ComponentAssembly = dispPart.ComponentAssembly
	if not IsNothing(c.RootComponent) then
            ReportComponentChildren(c.RootComponent, 0)
        else
            lw.WriteLine("Part has no components")
        end if
    Catch e As Exception
        theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
    End Try
    lw.Close
    End Sub
    Sub reportComponentChildren( ByVal comp As Component, _
        ByVal indent As Integer)
       Dim nazwa as string
       Dim path As String
        For Each child As Component In comp.GetChildren()
             If LoadComponent(child) Then
		Dim MyPart As Part = child.Prototype.OwningPart
	lw.open
	theBodyTags.clear()
	For each tempBody as Body in mypart.Bodies
 	       theBodytags.Add(tempBody.tag)
	   end if
	Next
'	lw.WriteLine("number of bodies found: " & theBodyTags.Count.ToString)
	    lw.writeline("no bodies to export")
	    return
	end if
	exportFileName = myPart.FullPath
        nazwa = myPart.Leaf
       path = IO.Path.Combine(IO.Path.GetDirectoryName(myPart.FullPath), "step")
	End If
       End If
       Try
       End Try
       lw.Close()
  	            Else
                'component could not be loaded
            End If
            reportComponentChildren(child, indent + 1)
        Next
    End Sub
    Private Function LoadComponent(ByVal theComponent As Component) As Boolean
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
            Else
                'component is partially loaded
            End If
            Return True
        Catch ex As NullReferenceException
            'component is not loaded
            Try
                ufs.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin,
csysMatrix, transform)
                Dim theLoadStatus As PartLoadStatus
                theSession.Parts.Open(partName, theLoadStatus)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            lw.WriteLine("file not found")
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        'warnings other than read-only...
                        Return False
                    End If
                Else
                    Return True
                End If
            Catch ex2 As NXException
                lw.WriteLine("error: " & ex2.Message)
                Return False
            End Try
            'unexpected error
            lw.WriteLine("error: " & ex.Message)
            Return False
        End Try
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
With best regards
Michael
