Stabilization are valid options but first I would like to know a bit more detail - say, for instance:
- what type of clay (fat, lean, etc)
- Atterberg limits and consistency index (where is the moisture content relative to the plastic limit)
- Are the clays expansive?
- Does the clay have a crust? (i.e., where is the groundwater level both now and in the past)
- What added grade will be used to achieve the parking lot level? - if the clay surface is 3 ft under the final parking lot level, the clay might not have that much influence given some select capping layer, subgrade and pavement sections.
- Are the trucks likely to be overloaded - or within the legal limits?
Get some information of this type and a better understanding of what might be required can be added to the valued comments given by inaz and gandersen.
![[cheers] [cheers] [cheers]](/data/assets/smilies/cheers.gif)
