Hi all,
I am very new to NX and the engineering work environment, and have just a college background using solid works. Currently I have an assembly made with parts from other jobs or folders that are loading fine. My issues is that I made a few parts on my own and loaded them in as assemblies, and that works perfectly fine. The problem is that when my boss or other go to view the file, the parts I created don't show up at all, only the boxed outline where the part should be. Other engineers have been able to change the load option to show the parts, which is only a solution for engineering. The parts need to be loaded every time as other non-engineers may not know to look for other loaded parts. This has become a major inconvenience for me. Is there anyway I should be saving the parts personally that I am currently not doing, or a load option setting that I am completely missing. This is not a layering issue, as that is what I first thought it was, but the parts load completely for me when I open the files after closing NX.
Any help or insight would be greatly appreciated.
P.S. I can not upload or share the files on here as they are protected documents.
