Part "Save As" Journal, Cant use "__00" for name suffix?
Let me explain a little better...
I'm using NX Native revision controls.
The File naming suffix drives the revision and what part to load.
__00 = Rev -
__01 = Rev A
__02 = Rev B
& so on.
The Journal below is what I've used for a long time to re-name parts
For some crazy reason if I attempt to rename...
XXXXX_PN-001.prt to XXXXX_PN-001__00.prt or __01.prt etc...
it just doesn't do it
But if I rename the entire name it works
This_dumb_part.prt to XXXX_PN-001__00.prt
That works!?
Is there something in this journal restricting the naming when it comes to underscores????
Option Strict Off
Imports NXOpen
Imports NXOpen.UF
Imports System
Imports System.IO
Imports System.Environment
Imports System.Windows.Forms
Module Renomear
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow()
Dim workPart As Part = s.Parts.Work
Dim displayPart As Part = s.Parts.Display
If workPart Is Nothing Then Return
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Renomear")
Dim filename As String = ""
Dim wpPath As String = workPart.FullPath
filename = wpPath
If (select_file(filename) <> DialogResult.OK) Then
Return
Else
Dim partSaveStatus1 As PartSaveStatus
Try
partSaveStatus1 = workPart.SaveAs(filename)
Catch ex As NXException
lw.WriteLine("SaveAs of part " & filename & _
" failed with error code " & ex.ErrorCode & vbCrLf)
lw.WriteLine(ex.ToString)
End Try
End If
End Sub
Public Function select_file(ByRef filename) As DialogResult
Dim sfd As SaveFileDialog = New SaveFileDialog()
Dim result As DialogResult
sfd.Title = "Choose new part file name"
sfd.AddExtension = True
sfd.DefaultExt = "prt"
sfd.FileName = filename
result = sfd.ShowDialog()
filename = sfd.FileName
sfd.Dispose()
Return result
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
TIA
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
Do you get any sort of error or warning message?
Using NX 9 (on Windows 7), I created a test part named 12345_PN-001.prt and used the journal to save-as to 12345_PN-001__00.prt; the journal successfully performed the save-as.
www.nxjournaling.com
No there were no warnings at all.... it was weird.
It's behaving well now tho. I think it may have been an under spec machine getting a little overwhelmed?
I'll be keeping an eye on it.
Dave
NX11, Win 10 Pro
