I think that's considered a "Flexible Wind Connection". Or, pretty close to it.
I've never used them myself. But, the AISC LRFD 2nd edition volume II had a design procedure for it. Some caveats:
a) You're supposed to have a simple shear connection as well, like a shear tab or such.
b) You can't mix and match this with other moment connections.
c) Beams must be capable of resisting full gravity load as if it's merely a simply supported beam.
There are other restrictions likely as well. But, like I said, I've never used this in practice..... And, whatever you do, do NOT use this to resist seismic loads.
