abusementpark
- Dec 23, 2007
- 1,086
I see where most engineers only require wood floor trusses in these type of structures to be designed for 40 psf LL without any explicit consideration for the non-load bearing partition load within residential units. I am aware of the TPI 1 exception that allows non load-bearing partition load to be neglected for the wood floor truss design, which I assume is the basis for this.
Does this mean most engineers are neglecting it for the overall building design (e.g. load-bearing wall studs, foundation, etc.)? I could definitely see the logic in doing that if we are saying the floor trusses don't need to be designed for it, then why would elements further down the load path with greater tributary area need it included? Also, I assume you'd still be accounting for the self-weight of load-bearing walls, party walls, corridor walls, etc. I am just talking about neglecting the partition walls within residential units.
