Hi all
I have been engaged to design 4km of soldier pile wall ranging from 0.2m to 2.4m high. Due to the length of the wall I would like to make sure I am not being unnecessarily conservative in the design. The walls will be founded in class 1 clay fill in a new residential estate. The typical design is a steel UB post encased in 450 dia concrete at 2.4m centres. Concrete panels span between the posts. I am calculating 1.6m embedment for a 1.2m wall, and 2.6m for a 1.8m high wall, but believe this can be reduced. The geotech has provided long term design values of density = 20kN/m3, c'=0, phi =30 deg.
• I have taken the friction angle of 0.66*phi into account to reduce the active pressure on the concrete lagging. Is it possible to take the friction into account for the passive pressure and if so over what width would it act? Assuming friction between pile and soil of 15 deg, kp = 4.3. Assuming an effective width of 3*pile dia this is an effective kp of 12.9. Is this friction already taken into account in Broms kp factor of 3?
• Does anyone have any opinion on the suitability of Broms for small retaining walls? I have used Broms assuming rotation about the base for the walls up to 1.4m high and then used the traditional limiting equilibrium method, calculating the actual rotation point for the higher walls (however still using an effective width of 3x dia as opposed to 0.08*phi).
• Some publications suggest ignoring the active pressure behind the pile, some say it acts over the pile width only and others suggest it acts over the full effective width of up to 3 x dia. I have assumed it acts over 1 x dia for walls over 2m and ignored for lower walls.
• Does anyone have any thoughts on phi of 30 deg and c'= 0 for stiff clay? I assume that phi is a bit high but accounts for any long term cohesion that may be present.
Thanks in advance
Thanks in advance
