Paste as part body macro
mrawlinc
Industrial
SI
I have macro which generates parts (and assembly of new parts) from each body in multy-body part, but they are pasted as normal (second) body. What would like is that this new (pasted) body would be Part Body. any ideas?
add few line (one might be enough) to the script to make the new pasted body the main body.
Eric N.
CATIA.ActiveDocument.Part.MainBody
regards,
LWolf
I managed to "convert" newly pasted body to Part Body:
Code:
Set partDocument2 = CATIA.ActiveDocument
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Set part2 = partDocument2.Part
  sel.Add part2
  sel.PasteSpecial ("CATPrtResult")
  part2.MainBody = part2.Bodies.Item(2)
  part2.Update
now I would like delete first (empty) body, but simply adding to selection and delete doesn't work in this case...
Code:
  sel.Add part2
  part2.Update
  sel.Clear
  sel.Add part2.Bodies.Item(1)
  sel.Delete
  sel.Clear
check again your bodies collection. I have the feeling that when you define one body as main body it become bodies.item(1)
that would explain why nothing happens in your case as you can not delete main body.
If I am correct simply change to
Code:
sel.Add part2.Bodies.Item([COLOR=#EF2929][b]2[/b][/color])
sel.Delete
Eric N.
I tried this way, as default (empty) body name is always the same, but also nothing happened...
Code:
sel.Add part2.Bodies.Item("Body.1")
sel.Delete
sel.Clear
It might help if I paste entire macro code, so you can test it (bottom third is where body delete should happen):
Code:
Sub CATMain()
Dim i, n As Integer
Dim name, prt As String
Dim BodyName() As String
Dim partDocument1 As PartDocument
On Error Resume Next
Set partDocument1 = CATIA.ActiveDocument
If Err.Description = "Type mismatch" Then
      MsgBox "You must have a CATPart as active document"
    Exit Sub
End If
name = partDocument1.FullName
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Dim sel As Selection
Set sel = partDocument1.Selection
Dim documents2 As Documents
Dim partDocument2 As PartDocument
Dim part2 As Part
Dim specsAndGeomWindow1 As SpecsAndGeomWindow
n = bodies1.Count
If n = 1 Then
  MsgBox "There is only one body in:" & Chr(13) & name & Chr(13) & "Part MUST have at least 2 Body's" & Chr(13) & "Macro will end now!!!", vbExclamation, "Warning"
Exit Sub
End If
prt = Left(partDocument1.name, Len(partDocument1.name) - 8)
For i = 1 To n
ReDim Preserve BodyName(i)
  'BodyName(i) = prt & "_" & bodies1.Item(i).name
  BodyName(i) = bodies1.Item(i).name
  sel.Clear
  sel.Add bodies1.Item(i)
  sel.Copy
Set documents2 = CATIA.Documents
Set partDocument2 = documents2.Add("Part")
  partDocument2.Product.PartNumber = BodyName(i)
  sel.Add part2
  part2.Update
'---------------- Where delete of empty body sould happen
  sel.Clear
  sel.Delete
  sel.Clear
  partDocument2.SaveAs Left(name, Len(name) - Len(partDocument1.name)) & BodyName(i) & ".CATPart"
  specsAndGeomWindow1.Close
  partDocument2.Close
Next 'i
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim productDocument1 As ProductDocument
Set productDocument1 = documents1.Add("Product")
productDocument1.Product.PartNumber = "Product_From_Part_" & Left(partDocument1.name, Len(partDocument1.name) - 8)
Dim product1 As Product
Set product1 = productDocument1.Product
Dim products1 As Products
Set products1 = product1.Products
Dim arrayOfVariantOfBSTR1(0)
Dim constraints1 As Constraints
Set constraints1 = product1.Connections("CATIAConstraints")
Dim reference1 As Reference
Dim constraint1 As Constraint
Dim ConString As String
For i = 1 To n
  ConString = ""
  ConString = "Product_From_Part_" & prt & "/" & BodyName(i) & ".1/!" & "Product_From_Part_" & prt & "/" & BodyName(i) & ".1/"
  arrayOfVariantOfBSTR1(0) = Left(name, Len(name) - Len(partDocument1.name)) & BodyName(i) & ".CATPart"
Set products1Variant = products1
  StrConstrain = "Product_From_Part_" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "/" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "_PartBody.1/!" & "Product_From_Part_" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "/" & Left(partDocument1.name, Len(partDocument1.name) - 8) & "_PartBody.1/"
  products1Variant.AddComponentsFromFiles arrayOfVariantOfBSTR1, "All"
Set reference1 = product1.CreateReferenceFromName(ConString)
Set constraint1 = constraints1.AddMonoEltCst(catCstTypeReference, reference1)
Next 'i
CATIA.StartCommand "Fit All In"
End Sub
read my post again
Eric N.
you have a line that says
On Error Resume Next , this is to deal with type mismatch of your file (should be a part and not a product)
finish this by putting On Error goto 0:
MsgBox "You must have a CATPart as active document"​
Exit Sub​
End If
on Error Goto 0
this will help you find any errors...
regards,
LWolf
I agree with itsmyjob, you need to take a look at your bodies collection after you reassign the partbody.
Prior to pasting, if there is only one body in the part, just set that to a variable and delete it after you paste
Code:
Set oBodyToDelete = oPart.Bodies.Item(1)
'Paste
Catia.ActiveDocument.Selection.Add oBodyToDelete
Catia.ActiveDocument.Selection.Delete
If there are multiple bodies in the part, you could run into other issues:
Note that in code, all bodies appear at the root of the part so if you have just the part body with several bodies nested inside using boolean operations, all of those bodies will appear at the root.
You can loop through the bodies collection and see if the bodies are at the root of the tree
Code:
For i=1 to oPart.Bodies.Count
[indent]set oBody = oPart.Bodies.Item(i)
If oBody.InBooleanOperation = False then
[indent]'Part is at the root of the tree[/indent]
End if[/indent]
Next
Once you know it is at the root of the tree...if you know it is empty you can check to see if it has shapes
Code:
If oBody.Shapes.Count = 0 then
[indent]Catia.ActiveDocument.Selection.Add oBody
Catia.ActiveDocument.Selection.Delete[/indent]
End if
