Patran/Nastran doesn´t generate the .XDB file
DavidFEA12
4
i´m doing an analysis, but when is time to get the results (.XDB file) there´s not any file in the working directory
checking the .F06 file, it says:
*** SYSTEM FATAL MESSAGE 6357 (SEP1A)
NO GRID POINTS FOUND
Someone know something about this or is having the same issue?
also is giving me other warnings:
*** SYSTEM WARNING MESSAGE 6299 (PARCPU)
NO PARALLEL PROCESS CREATED
*** SYSTEM WARNING MESSAGE 3001 (SEP1X)
THE INPUT DATA BLOCK NAMED GEOM1QS AT POSITION 2 DOES NOT EXIST.
THE INPUT DATA BLOCK NAMED GEOM2QS AT POSITION 3 DOES NOT EXIST.
attached are the .f06 & .f04 that the software is giving me
Thanks!
Hello DavidFEA12,
Can you show us your bulk file ? It is difficult to answer you without more information.
