Pattern Shape along curve with rotation 1
jagandeep
Automotive
May 27, 2013
82
Hello Friends
I want to pattern rectangular sectioned shape along curve such that base of rectangle should be tangent to curve. Also size of all the sections must be linked so that i can very it at any time. Is it possible somehow by hook or crook [bigsmile]
Screenshot is attached here for reference
Jagandeep
 http://files.engineering.com/getfile.aspx?folder=80ea4bce-7f0d-4af9-a8db-3038d3508821&file=Pattern.png
you need a script or Knowldege Temple license or you do it a mano
Eric N.
your question is so confusing,
" want to pattern rectangular sectioned shape along curve " do you want to sweep that section along the curve?
Where you want tangency?
3) Publish the sketch, and translate linked sketch where ever you want,. this way you can change anytime and all sections gets updated.
regards
var
ok Got it,
First metnod,
1) You have points on curve already.
2) Create axis system on the point with one axis tangent to curve
3) then you would ahve axis system on your base traingle too. (Again one axis parallet to one of the line)
4) Then do axis to axis translalte.
tip- i create one set and paste and just repleace the point​
Second method
You can put above 1,2,4 in script.
hope this helps
var
