I'm working on a job where we are redeveloping an existing gas station. Part of the scope is to replace all the asphalt on the job. This was due partly to the asphalt's condition, but mainly because I had to regrade the pavement to accomodate changes. I would like to avoid replacing the pavement full depth, meaning I would like to keep the base aggregate. What, if anything, should I be concerned about when reusing an existing base aggregate? My thinking is if we get a proctor on the material and make sure its compacted properly, we don't need to worry. I guess something makes me think you would need to remove it all or place it again.
