thread794-476044: ASME PCC-2 Fillet Welded Patch Repair JAR10 Just saw your 2020 questions about PCC-2 Equation 5. Seems to be a "t" missing from the denominator of the second term. As is, that term is dimensionally incorrect. If hoop stress in original pipe is (PD)/(2t), hoop force per unit axial length is also (PD)/(2t). Edge moment on patch plate (per unit axial length) is (PDe)/(2t). Bending stress at outer fiber of plate is (PDe)/(2t)(T/2)/(T^3/12)= (3PDe/t)/T^2. Submitted a query about this to the code committee a few years ago. Never got a response.
