  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
PDF File generated from macro is "type 30" file
hims1980
Aerospace
Jul 9, 2012
54
Hi! Ferdo,
I used the catscript (from chm file) of converting cat drawing into pdf file & runned a macro, but the pdf file generated is showing as "type 30" file & not pdf.
I am following the same instructions like i have copied my all the cat drgs in C:temp folder.
Can you please provide some solution ?
Himanshu
Hi!
Below is the script:
[highlight #000000]Language="VBSCRIPT"
Sub CATMain()
MsgBox "This will not turn in black your background view and at the end the drawing will be closed with last save done manually"
Dim theDrawing As DrawingDocument
Set theDrawing = CATIA.ActiveDocument
Dim mySelection As Selection
Set mySelection = theDrawing.Selection
mySelection.Search "Type=*,scr"
Set visPropertySet1 = mySelection.VisProperties
visPropertySet1.SetRealColor 0,0,0,0
mySelection.Clear
theDrawing.ExportData "C:\temp\" & "\" & Left(CATIA.ActiveDocument.Name, Len(CATIA.ActiveDocument.Name) - 11), "pdf"
theDrawing.Close
End Sub[/highlight]
The CATIA Version i use is CATIA V5 R20 SP6
Himanshu
Hi!
I am sorry for my highlighting the script.
Please find below again
Language="VBSCRIPT"
Sub CATMain()
mySelection.Clear
theDrawing.Close
End Sub
Himanshu
Play a little bit with the line bellow by replacing 11 with 10 or 12 (or other figures) and see what is going on (try to understand how string manipulation is working).
Why don't you use the build in CATIA command to save as pdf? Do you have some special reasons?
Fernando
Hi!
A bunch of cat drawings at a time of around 20 to 30 are need to be saved in PDF. That's why i selected to go for a macro.
Himanshu
Ferdo, figure 10 works out for me.Thanks....
Can you please explain me the "string manipulation" for this macro ? How did to choose to edit this figure ?
If i want this macro to be edited for batch mode, how should i edit this script ? Please give any hints ?
Meanwhile, i am also thinking on that, it's not like i had simply left it on you.
Himanshu
