PE Exam time limit?
tnteng
58
Does anyone know if there is a maximum time that can pass (after passing the FE exam) after which there is a problem taking the PE exam?
Thanks,
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
Every state has its own minimum, none seem to have a maximum. From an outsider perspective, it looks like they have a checklist (in fact one state returned the filled-out checklist to me), and the one I saw just said "Completed FE".
David
tnteng,
I know in Massachusetts your FE certificate is good for 6 to 7 years. After that, you may have to take the FE exam again.
Go Mechanical Engineering
Tobalcane
In CT you have 10 years before you need to retake the FE.
ChemE, M.E. EIT
"The only constant in life is change." -Bruce Lee
