Hello everybody,
I am designing a heat exchanger which involves corrosive materials, which excludes any metal as possibilities as materials. I seem to have narrowed it down to PE by comparing polymers with their respective thermal conductivities.
Now I am faced with the choice between High Density Polyethylene or Polyethylene with a FEP liner. The second has slightly thinner wall thickness, but I am not sure of it's thermal properties.
Is there anybody out there that might be able to tell me if the FEP liner is likely to improve PE's properties or the opposite.
Thank you
Domenic
Thank you
Domenic
