Inchtain
Petroleum
- Feb 21, 2021
- 132
We are purchasing a new condenser (Heat Exchanger) for a LNG Plant.
We wonder if we request an ASME or PED Stamp from the manufacturer? and what is the main differences between those 2 stamps, apart from ASME for America and PED for Europe
The Heat Exchanger Data:
Fluid: Shell: Hydrocarbon Gas / Tubes: Cooling Water
Design Pressure: Shell: 29.42 Bar / Tubes: 20.6 Bar
Design Temperature: Shell: 90 Degrees Celsius / Tubes: 70 degrees Celsius
Materials: Shell: SA 333 Gr. 6 / Tubes: SA 334 Gr. 1
Exchanger Type: BEM
Exchanger Dimensions: Dia. 381 mm * Overall L 6927 mm
Design Codes: ASME VIII Div. 1- TEMA R- API 660- 2014/60/EU
Thanks for your cooperation
Exchanger Type: BEM
