casasf
- Dec 11, 2009
- 47
I am designing a pedestrian bridge having a span of 90 feet and the transverse direction is 12.5' Steel tube trusses are being designed. For the floor I have a metal deck with concrete over a horizontal truss, Where the edges are the bottom chords of the vertical trusses, i have diagonals and vertical legs. In other words a trusses turned on its side.
The question I have: The aspect ratio for diaphragms must not exceed 4:1 Is there another aspect ratio for Bridges where i can use and delete the diagonals? In other words, the truss will become a Vierendeel truss? Does any one know if there is an aspect ratio. I try not to use the Vierendeel truss as each joint will be complete pen weld and will reuire UT. Your help will be very much appreciated.
