LUISGUTIERREZ
The attachment, labeled SOUTH ANCHORAGE, shows a pedestrian suspension bridge built in a resort area in Central America. The span is about 90 meters. The main cable (on either) side is composed of three cables of about 1 inch in diameter. The bridge collapsed recently due to overload that broke the "eye bars" of the south anchorage. The eye bars of the NORTH ANCHORAGE did not break. The cable did not break either. If you examine the pictures carefully you will notice a difference that may explain the difference in behavior of the anchorages.
I am not a bridge engineer but I am getting the idea that designing a suspension bridge in this scale may be a task accessible to non-specialized structural engineers. Would the participants in this forum provide technical references with guide lines for design and construction of this kind of bridge. I will appreciate information. Also, do you notice the two small wires bracing the columns in the picture of the south tower? It seems they were needed during construction, but do they serve any purpose after completion of the structure? Will appreciate your insight.
