LOKSTR
- Apr 15, 2005
- 122
Hi Everybody,
I am looking into a foundation drawing for a PEMB( pre-engg. building). The building is not having any concrete slab. To tackle the horz. forces(50k factored) I need to have a 1-1/2" dia solid tie rod from one column to another.
The foundation will be of steel screw piles with steel beam cap on top of them.
Will much appreciate if someone can shed any light on followings:
1. Do the screw piles need to be designed for 50k horz. force or not?
2. What will be the load path for this horz. force in the absence of concrete slab. Will the tie rod hold the columns from moving out and no horz. force need to to be trasferred to piles and then to ground ?
