VSS Engineering
- Jul 3, 2023
- 7
My team is designing a grandstand, which we have done quite a few of over the years. This one in particular has a press-box at the top that is designed by a different engineer. We're having a bit of a disagreement on the risk cat. for the press-box design. The press-box EOR is dictating the press-box as a risk cat. II structure, where we believe it should be a risk cat. III structure since the support structure, the grandstand, is risk cat. III.
Has anyone dealt with a similar situation or have a code reference that provides direction as whether or not a "penthouse" risk category has to match that of the support structure?
