Performance curves on simulink
jocamc
18
I want to use a performance curve of a turbine in a simulink diagram. Can anyone tell me if there is a block or a tool in simulink wich I can use to put this characteristic curve?
Tks in advance!
Not sure I understand the question. A performance curve is a series of ordered pairs of numbers, i.e., an array. How are you getting numbers into your Simulink now?
TTFN
faq731-376
7ofakss
Well I have two inputs. One of them, for now, is constant the other is a sinusoidal function. These two inputs combine in a specific formula which gives a value that I must then match in a performance curve. How do I build a block wich is a "performance curve"? Use some kind of array?
I've found something on the internet wich I think is the block I need but I dont know really wich is:
It's a lookup table.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
