Performance expectations from laser cutting phenolics
mjm6
Greetings group,
I am new to the fabrication/manufacturing end of engineering, so I would like a little help to determine whether the quality of cut I am getting from a laser cutter is in line with the rest of the world.
I have recently begun some prototype testing for a product that involves cutting phenolic resins (from .015 to about .030, some FR4, and some paper-based). These layers will then be laminated into an assembly that will be part of the product.
The parts are fairly small, and can be done on a desktop laser cutter/engraver, but I am getting a little bit of heat damage on the very edges of the cut pieces. I need to determine if this is the price to pay for using a laser, or maybe I neeed to direct the company doing the cutting to modify their cutting procedure a little.
The worst damage appears to be related to the paper based phenolics, and more specifically to the thinner products, however, I have not done enough testing to be absolutely sure if that is consistantly the case.
The damage is similar to a slight heat blistering that some plastics will do, and it appears to affect the lamination within the phenolic sheet.
Is it possible to get a good, undamaged edge when cutting phenolics? Are phenolic laminates compatible with a laser cutter?
I'm wondering if I need to try another laser cutter or possibly a different laser technology to get a better result. It may simply be that I need the cutter to try a different pulse rate or feed rate.
Any suggestions you may have would be appreciated.
Thanks,
---Michael
I believe that the edge damage is characteristic of a CO2 laser acting on these materials.
A different laser technology may work better- eximer?
Call a few laser manufacturers, check out the trade mags like Laser Focus, Industrial Laser (News?), etc.
There are also some very capable consultants out there.
Jay
Jay Maechtlen
He'll be able to reduce char by using Nitrogen or other non-reactive gas. I don't believe he'll totally eliminate it.
Actually, that's a good point- depending on what result he really needs, a CO2 laser may be "good enough"...
Or, it may not.
Cheers
Jay
Jay Maechtlen
Thanks guys,
I don't know the gas they are using, so I'll find out. If I can gete a cleaner cut, the CO2 laser will be sufficient for my purposes.
---Michael
