May 10, 2023 #1 Taylor W Geotechnical Feb 7, 2023 14 0 0 US Hi all, I am running a steady-state soils analysis in Abaqus, and no matter what I change the permeability to (other than zero), the results do not change. Is this correct, or am I doing something wrong? Thanks!
May 11, 2023 #2 FEA way Mechanical Nov 13, 2018 4,894 0 36 PL Which output don’t change ? Did you check the ones related to pore fluid flow ? Upvote 0 Downvote
May 11, 2023 Thread starter #3 Taylor W Geotechnical Feb 7, 2023 14 0 0 US Ah, you're right, the fluid velocity does change. Does it not affect the stresses and pore pressure? Those aren't changing. Upvote 0 Downvote
