Permeability not affecting soils analysis
Taylor W
Geotechnical
Feb 7, 2023
14
Hi all,
I am running a steady-state soils analysis in Abaqus, and no matter what I change the permeability to (other than zero), the results do not change. Is this correct, or am I doing something wrong?
Thanks!
Which output don’t change ? Did you check the ones related to pore fluid flow ?
Ah, you're right, the fluid velocity does change. Does it not affect the stresses and pore pressure? Those aren't changing.
