Perpetual Motion Machines in Jets !!! ---- This is where the Industry is headed !!! 2
MJCronin
5,097
Damn ... That conservation of mass and energy is sooooo yesterday !!!!
As you can plainly see from the 3D model, the atomic whiz-bang thingie between generator one and generator two amplifies the "ambient energy" in the MBA force field around the vehicle. Its all a simple matter of Advanced Phologiston Theory
You can get out 14 times what you put in ....
To quote the CEO on LinkedIn:
I am proud and excited to share the news of our updated prototype - ElectroEdge. Our final test was carried out on May 2nd, 2022, and energy generation was 14 times more than the input. It is about time to fly electric planes longer and faster without carrying heavy batteries.
and, from their website:
Panhwar team continuously clung to the belief that “Whatever you think, you can do it. You are the only person who knows you can do it. Don’t listen to other people if they try to put you down,” Nick says. “At one time, I was told I was a complete idiot. But take those things as motivation and try your best. You are the one with the idea. Others haven’t done it, so they think it’s impossible. But if you think it’s possible, never give up on your dreams.”
MJCronin
Sr. Process Engineer
Wow. If only there was some way I could give them some money!
That plane seems to be very similar to the first picture in this thread. A bit of plagiarism maybe?
Where are the"details" MJC?
The website is devoid of anything even vaguely technical.
The renderings are an insult. If you're gonna steal money, do it with a bit more attention to detail.
Some gullible VC has chucked 10 million bucks of somebody else's money into this.
On May 2, 2022, a final test was conducted with an updated prototype, where ElectroEdge produced 7.36kw (AC) given the input was merely 511watts (DC), meaning it generated over 14 times more energy compared to the input (Output: 120volts and 61.3amps: Input: 22.2V and 23Amps). Above all, ElectroEdge can be entirely customizable based on load and application demands.
Bear in mind that this prototype was 3D printed, according to Co-Founder and Chief Engineer Nick Panhwar, around 35% of the efficiency is naturally expected to intensify when the unit is constructed with titanium and aluminum.
Cheers
Greg Locock
Wow - if they are getting a power gain they should try putting a few dozen of these in series. With that amount of energy available we can start building Ring World.
LAS VEGAS! I feeeel lucky!
If I were to be charitable for just a moment....
Do we think it's possible they genuinely measured both 120 volts and 61.3 amps, just not the phase relationship between them?
A
"Defying the law of physics through the Panhwar energy system that proficiently powers electric plane"
You gotta like the alliteration there. I'd donate a few French francs to the cause...since they're worthless now anyways.
suppose one Swensen has a group of clients.that need to generate some losses to offset real gains elsewhere...
Then they'd be on-par with the corporate donations/write-offs that fund much of university "research" today.
I've worked with quite a few similar entrepreneurs in engine development. The bit I always find interesting is googling founders' careers, many tend to be serial entrepreneurs with businesses ranging from fast food to spaceflight.
Well, go with what you know I guess...
Assuming the image in the OP is an accurate mock-up of the test setup, what are the odds that they tested this thing in an open field with the wind blowing across the 'Turbine' blades? So they use a little fan to blow on it and measure the power input at the motor leads, but then the wind skews their results and spins the turbine 14x as fast as the little fan could?
You think it was even a real, physical test? Or a simulation, maybe?
The fact that they don't see a problem with stating, "DEFYING THE LAW OF PHYSICS THROUGH THE PANHWAR ENERGY SYSTEM THAT PROFICIENTLY POWERS ELECTRIC PLANES" is a problem in itself. Getting above unity is cray-cray enough, but 14x?
TTFN (ta ta for now)
"Jet"
"I do not think it means what you think it means." I can't believe the internet has allowed that gif to exist...
phamENG, I plead guilty of carelessness in my selection. I only really looked it after posting. Do with me what you will :)
