Pervaporation Mathematical Model
KedarS
Chemical
Feb 26, 2003
0
IN
I need a mathematical model for Pervaporation for simulation. Any book/url/helpful tip may work. Thanks in advance.
Kedar
Try contacting Dr Robert Field at Oxford University UK. You could also try Bath University Chemical Engineering Department who have done some work in this area.
David G
Hi Kedar,
you may look for this literature:
A. Heintz, W. Stephan: A generalized solution-diffusion model of the pervaporation process through composite membranes
Part I. Prediction of mixture solubilities in the dense active layer using the UNIQUAC model, Journal of Membrane Science 89(1994)143-151.
Part II. Concentration polarization, coupled diffusion and the influence of the porous support layer, Journal of Membrane Science 89(1994)153-169.
Heintz and Stephan used PVA/PAN membranes for their water/alcohol separation experiments and simulation, resp.
Please note: Influence of liquid boundary layer and the membrane support, resp., can be essential and should allways be considered!
B.K. Srinivas, M.M. El-Halwagi: Optimal design of pervaporation systems for waste reduction, Computers chem Engng, 17(1993)957-970.
Connection of several PV stages for optimal network operation.
Best regards
Lorenz Kraetz
Hi Lorenz,
Thanks for your help. The references ypu have suggested are more on the Sorption-Diffusion modeling of pervaporation. I'm working on the Pore flow model of Pervaporation. Still I'm stuck up at the determination/calculation of the surface viscosity. Please can you help me in that respect?Thanks.
Kedar
During the Achema show being held from May 19th through 24th in Frankfurt, Sulzer Chemtech Membrane Systems will be showing the latest developments in the field of pervaporation and vapor permeation and introducing the new PERVAP-Tools, which can be used with process simulators such as ProII to simulate and optimise flowsheets which combine pervaporation with distillation and other unit processes.
The following papers will be presented at the Achema-conference:
"Process Simulator Toolkits for Pervaporation and Vapour Permeation" - Nick Wynn, on Wednesday 21.05.2003, 3.30 p.m., Room: Harmonie 1, CMF
