NickParker
- Sep 1, 2017
- 444
The questions are regarding switching sequence of PF capacitor with regards to both the LV and MV Motors.
A. Which is the better way to start a motor?
1. Starting a motor with the PF capacitor already switched ON, so that the capacitor assists in Motor starting.
(or)
2. Switching the PF capacitor with a slight time delay after the motor is switched ON, so that capacitor is protected from the Motor Inrush current
B. Similarly for switching OFF,
1. Should the capacitor contactor simultaneously switch OFF with the motor contactor?
(or)
The capacitor contactor switch OFF first and then the Motor contactor switches OFF to avoid over excitation problems.
C. Does simultaneous "Switching ON" and "Switching OFF" of contactor produces voltage transients?
D. How about the voltage transients when the capacitor contactor switching is delayed slightly?
E. How about the voltage transients when the capacitor contactor is switched OFF before the Motor contactor is switched OFF?
(or)
(or)
