karalahana
Hi, I am hesitating in this issue (POWER FACTOR CONNECT?ON CAPAC?TORS' L?NE PROTECT?VE FUSE RAT?NG )since I am not sure to which criteria we must select the fuses. I mean must we use a motor fuse since the in rush current makes necessary that a delaying type fuse is used. If this is so for sure (I am asking you of this) so what ratio must be between capacitor rated current and fuse rated current? I am confused since there are some sources which says at least 1,5 -1,6 ratio must be between them. Thanks a lot.
