Sorry about that. I worded the question wrong. I understand how a relay works. What I had a question about was when the DC circuit energizes the coil, what is the correct contact rating. Why did you choose 10 amps? Just to make sure the rating is a couple hundred times bigger than the current going through the relay which is around 30mA. Wouldn't 5 amps be okay? Also, what sort of issues could I run into with this configuration
