Photoview 360 is great, but...
321GO
Automotive
Jan 24, 2010
345
- Hi Guys
**Photoview 360 question**
Although it redenders like a champ, i'm not able to align the part once opened in photoview.
Furthermore, the walls and floors have destinct (i suppose) "light reflection patterns", which creates unnatural sharp color transitions.
Basically, where are the setting?!
Thank you in advance.
Actually, there are settings you can use to manipulate some of the lighting to make things more realistic using the 'Settings' button. You can change the angle of the light in relation to the part/assembly.
As CBL said, you should check out Rob's blog. The boy has skilz.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
