CBSE
- Feb 5, 2014
- 309
I'm working on my first Pile Foundation supporting building in about 8 years...which was done at a company I no longer work for. It's a really simple building, one story, rectangular 90x60, and an Essential Facility.
Questions I have:
1) I received the soils report from the Geotech and I have vertical load capacities for 10" & 12" diameter piles hollow steel piles. Is it my responsibility to determine the steel wall thickness of the piles? I can't find it anywhere in the Geotech Report.
2) Is it more preferable to fill these with Concrete or weld a 1" thick by 14" square steel cap on them with headed nelson studs? I have my detail created for filling the pile with concrete, but was asked to show one with a steel cap as well.
3) For my lateral loads on the building, I'm assuming the Geotech will need this info to determine whether or not the Pile Spacing I have determined as adequate will work?
4) Do I need to check the steel piles for bending adequacy from my lateral load calcs?
5) Does anyone have any good references for structural notes for piles that I could look at?
Thank you!
Questions I have:
Thank you!
