MPHenry
- Mar 16, 1999
- 53
Consider the following hypothetical situation. I have a heavy reinforced concrete raft foundation pad, 400mm thick which will be constructed on a loose to medium dense sand. The Geotechnical Report recommends that the foundations should be constructed on piles to reduce differential settlement. Is it possible to cast the raft on a series of bored concrete piles without using pile caps or directly connecting the piles to the raft itself? Lateral stability will be provided by passive soil resistance as the raft foundation pad is constructed at basement level, 3m below final grade.
Mike
Mike
