Pilot operated PSV
kmg1983
34
Hey guys...For Crude oil application, we have a pilot operated pressure relief valve, set pressure of 235 psi, which has recently been "leaking by" with only 14-15 psi on the line. What are possible causes of this? There is a filter screen installed in the pilot sense line which may be plugged or clogged with debris, this is my thought...any other thoughts as to what may be causing this? The main valve has been sent in for service and cleaning once before after a similar issue. Also, can someone explain the concept behind the proper operatin of a Pilot Operated Safety Relief Valve (differential pressure, etc)? Thanks in advance.
Please do not post multiple copies of the same question.
You already have 3 answers to this question in your other post.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
