Pin to Pipe Connection
alwayslearning123
6
How would you analyze a pin to pipe connection, where the pin is perpendicular to the plane of the pipe. The pin is connecting to a shackle, which will be pulled perpendicular to the plane of the pipe and the pin. The design is not a simple shear plate connection.
Can you post a sketch of the connection?
Mike McCann
MMC Engineering
