PotashMechy
Hi All,
I am trying to determine the force required of a cylinder to keep a plate pushed down, and to pull it up when needed. The cylinder is pinned at both ends. The plate is resting on a beam at one end, and is pinned at the other end to be able to pivot. The loads acting on the plate include its own weight, and considerable winds pushing up from beneath.
How would I solve for the required force of the cylinder? If my free body diagram of the plate is correct, I have more unknown forces than available equilibrium equations. Is there a simpler way to size a hydraulic cylinder?
Angle is 24.5 degrees,
Plate load is 1448 N
Wind load is 10,000N
Drawing of the problem is attached.
