I am designing a flex building with steel bar joist and CMU block bearing walls. The architect is showing very tall parapet walls above each storefront entrance. The parapet walls are about 24 ft long x 10ft tall.
I designed this pipe brace system (attached). I don't feel great about it because I feel like it will be expensive and it may leak. The roof slopes towards this parapet wall. I will have (3) braces per parapet wall - so braces will be spaced at ~ 10ft.
I am open to suggestions.
