uaepiping
- Feb 3, 2013
- 106
Dear Experts,
In one of our plants, the clamp supports displaced from the sleepers and fell down. The line data is like this:
Size = 10"
Design Temperature = -22 °C
Operating Temp = -8°C
Design Pressure = 27 Barg
Operating Pressure = 10 Barg
The line is connected to a 24" line which is connected to pump discharge.
Line Material = ASTM A333 Gr. 6
Insulation = Cold
Supports are on the cold insulation.
The problem as we could see is that gradually clamps slipped over the insulation and fell down ultimately.
This may have happened overtime with the movement of pipe due to start/stop of the pump (as it is not continuous running pump - a tanker filling pump) and line shrinkage. The sleeper top plate has a round bar welded on it and the shoes of the clamp support rest on it. The sign of slippage were clear during the site inspection. These supports are clamped over 1mm thick cladding steel plate.
Question to all of you:
How to hold the clamp on cladding so that it does not slip. We need to do it while the line is in operation; without removing insulation. So any solution for this problem?
Size = 10"
Insulation = Cold
