I was asked to figure out the amount of deflection in a pipe for two different lift contact points - with the majority of the load lift from the center and then with the load lifted from one end.
Originally I thought this would be a quick calculation where I could pull the equations off beam deflection tables, however when I did so the deflections I got were somewhat higher than I expected.
My parameters are: 50' length (yes, quite the long length!), 8" sched 40 steel pipe. It will either be lifted from one edge, or the middle (another strange thing, since I'm sure it would be too cumbersome to actually lift a 50' long pipe from only the middle).
From my understanding, the beam tables show either cantilevered beams or fixed-fixed beams. So is it possible to correlate these criteria to the fact that the beam is technically not fixed at any point?
Thanks!
Annette
Thanks!
Annette
