Pipe discharge configuration
essenwood
Chemical
Mar 6, 2003
25
Hi guys,
I always see that the drain valve on a pump discharge is between the NRV/check valve and the downstream block valve (NRV, drain valve, block valve). Is there a particular reason why the arrangement is like that? I.e. can I have instead the drain valve up stream of the NRV? (drain valve, NRV, block valve).
Thanks in advance.
There would be product trapped at operating pressure between the check valve (NRV) and the block valve.
Think about it.
Q If you've shut a pump down- how do you drain down the piping downstream of the check valve?
A The first thing you put downstream of a check valve is a drain (unless the pipe slopes down- that minimises the dead section you can't drain otherwise.
The drain location is not always in the same place, it could also be in the pump casing. It depends on a lot of different factors for example Hazardous nature of chemical, pipe orientation etc. The drain location is usually discussed at great length when a HAZOP study takes place.
Roy
Dear all,
Thanks for your replies.
I was thinking that the dead end section can be drained through the pump casing by way of a bypass line around the NRV.
