meca,
Since you said that the pipe moves when the "pipe has experienced sudden increases in flow rate," it also sounds like you are experiencing a temporary force imbalance due to transient flow.
Typically, for steady state flow, the force acting on a 90-degree elbow can be characterized as w*u, where w is the mass flow rate and u is the fluid velocity.
Consider, for example, that you have a straight pipe segment with a 90-degree elbow at either end. Then, at steady state the flow rate is the same at both ends of the pipe, so the forces balance out. During transient flow, two things happen. First, the flow rate may be different at each end of the pipe and for sudden changes in flow, a transient pressure wave may move through the pipe causing the pressure at either end of the pipe to be significantly different.
The pressure force is simply P*A, where P is the pipe internal pressure and A is the pipe cross sectional area. The pressure force acts in opposite directions at either end of the pipe segment (the momentum force also acts in opposite directions at either end of the pipe segment).
The duration of the force imbalance, the impulse, may also be of interest to you. The impulse is dependent on the pipe segment length, fluid sonic velocity, and the acceleration rate.
So, my point is that if you are asked to calculate forces for a variety of flow rates, you may actually want to calculate forces for various changes in flow rate.
Have a nice day.
TREMOLO
