I want to create an object having a pipe and a flange attached to it. But the flange axis and pipe axis are at an angle. How ot create a mate for this.
Also I want to create a TEE joint, but inner surface of my pipe is having a particular contour. If I create a plane at outer surface of the pipe then it does not gets joint on fully. If I take a plane at ineer edge of the pipe, some of the contour is getting cut. How to resolve?
Third problem:
Whenever I create a section view I have to check "Flip the side to view" to see a proper section view. Is there any variable to control this.
Arun "Knowledge is power"
Third problem:
