Pipe Minimum Wall Thickness Calculation Using EN 13480 - Part 3
Pavan Kumar
Chemical
Aug 27, 2019
375
Hi All,
May be this is the wrong forum to post my question, as this is a Pipe Pressure Design question. I am still posting this as I wanted to hear from Chemical Engineer's point of view of quickly calculate the pipe design design pressure given wall thickness and vice versa. It is simple in ASME B31.1 and B1.3. I am having a hard time with EN 13480.
I have assigned to check the design pressure of a Seamless Carbon Steel Pipe (EN 10217-2 Gr P235GH or EN 1.0345) for DN 400 (OD= 406.4mm) line size with a wall thickness of 11mm. The fluid is Saturated Steam at 16 bar(g) ( TSat= 204.345 Deg C). I went through EN 13480 Part -3 and got the formula for Pipe Wall Thickness without any allowances or tolerances.
e =( pc * Do ) / (2* f*z+pc) ------> From EN 13480-3 : 2002+A4
where,
e = pipe minimum wall thickness, mm
pc - calculation pressure or Design Pressure, N/mm2
Do - Pipe OD ,mm
f - Design stress or allowable stress, N/mm2
z - joint coefficient ( z=1 for seamless pipes)
Now the question which sections of EN13480-2 and EN13480-5 should I refer to get the values of f and z. Going through EN13480-3, I see that f needs to calculated as the lower of Time Independent and Time Dependent stress. This calls for determining many other values such ReH, Rp,0.2,t, Rm etc. I want to get some help in figuring these out.
Any guidance will be very helpful to me.
Thanks and Regards,
Pavan Kumar
Hi Pavan,
A Google search:
Consider this link about comparison between standards, it should help you.
Note: Tutorials about pipe thickness are available on YouTube channel.
Good luck
Pierre
The only person on this site who knows I think is XL83NL.
might try and contact him direct.
but a 16" line at 11mm is going to have a DP a lot higher than 16 bar, even at 204 C
See e.g.
Hi LI,
How can I contact XL83NL directly?.
Yes I checked using ASTM equivalent for EN 10217-2 and EN 1.4307 at a Design temperature of 204.345 Deg C and 11mm and 8 mm pipe wall thickness and got 43.8 and 21.7 bar(g) respectively. However my office wants me to do it using EN 13480 - 3!.
Thanks and Regards,
Pavan Kumar
  • 601.3 and 601.4 - Pipe Design Pressure Calculation.xlsx
